N
Ncfella
Looking for a little help please... running power to workshop.
My home has a 200amp service. Neutral and ground are bonded at meter on outside of home. Main breaker box in house has neutral(white) and ground separated. I have a 100amp breaker installed in the main panel which ran to a sub panel 140 feet from the house. That's where I had a 30 amp breaker for a camper.
Camper is gone and now I have a workshop. Here's my plan and question's.
Wire from 100amp breaker in home is the aluminum 4 wire (2-2-4-6). I plan to remove outdoor sub panels internals and splice the four wires inside the panel... then continue the four wires to the workshop breaker panel.
Panel in workshop is a 100amp with a main 100amp breaker. I plan on green wire to ground bar, black with white stripe to neutral bar, 1 black wire to 100amp breaker.
What to do with final black wire?
Also, will I need ground rods or does house where feed comes from ground it?
Lengthy post but just trying to give as much info as possible.
Thanks for any insight
This is a UK based forum but we have US members like @Megawatt so when he sees this you will get an answer.
Waste of time. And here's you going 25 efing characters
this forum is not a waste of time and since you are a do it yourself then all I’m doing to tell you is your extra black wire goes on a double pole breaker. You need to hire an electrician to do this install
