Discuss Press Switches and Labeling in the UK Electrical Forum area at ElectriciansForums.net
Dont have the switches yet but iam searching and looking for ways to label them too.These switches will be used on a plc system.
Ideally will be press/push 4 gang or more and if there is a light background option would be nice.
I have use some touch switches but find them not so reliable.If you touch it 100 time it will work 95times due to human error not touching the correct way or sometimes hands are wet or dirty.
My concern is not to just stick a label on the switches and look like a casual work but rather look polished and professional.Any ideas would help.
Get them engraved.
Engraved metal plates
Try Hamilton litestat , see loads of their accessories on posh jobs
Good idea, thanks. I checked if there is something i can buy to do it by myself but the money and the knowledge to buy 1 of those machines are prohibitive.
Best to send them the switches for engraving.
Get your own engraving machine and you can do it yourself. Much more permanent and professional looking.
Yes I did them with a cheap Chinese 3040 type CNC milling machine, controlled with Mach3. I use StickFont V2 as it's really fast and simple for text, and Vectric Cut2D Desktop for cutting out shapes, again as it's easy to use for someone like me with no CAD/CAM skills. Photo attached of the grid plate in progress.
Edit, these machines are highly hackable and I have made a number of changes, it now has a higher power spindle, I also modified the controller so the emergency stop button stops the spindle as well as the stepper motors.
freddo,
The results looks professional and you have that setup with just few hundred pounds.
If you will do it again will you go for a laser engraver instead of the milling ?
freddo,
I don't know, how well does laser engraving work on these types of materials? Milling and Traffolyte go well together.
I would have liked an electronic Gravograph but even second hand they cost thousands.
Reply to Press Switches and Labeling in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
