Discuss Pricing Apartments in the Australia area at ElectriciansForums.net
Cant give you an estimate but the way I do mine is list your materials and costs then you just have to guestimate your time for first and second fix add them together, add your percentage as profite and contigency and there you are........HOPEFULLY
or what about a cost to wire each apartment.I know the cost to rewire a 3 bedroom house is around £2500 to 17th edition.
I often price rewires etc by point, then add in a CU change, bonding, smokes etc. depending on my workload will depend on the cost per point. Then add something in for lifting boards, plastering etc. This may be a little more complicated depending where the meters are located.
A friend on mine works on a rewire cost of £30.00 per point regardless in it’s a socket, light or switch. £100 for a shower and cooker. He also adds in a cost for lifting floor boards etc. he gets a lot of work.
Ian
Ian
£30 per point:eek:
No wonder he is busy!
Reply to Pricing Apartments in the Australia area at ElectriciansForums.net
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
What is it with the recent prices I'm getting at wholesalers, just about everything anyone quotes now is about 20% dearer than I can get things...
9K
Hi all, I hope you could share your experience and advice regarding supply 50 flats in 5 storey block of flats. We get 3 x 430A supply. What...
HI , potential 2 bed 1970’s bungalow buyer here…. Our surveyor (RICS) has pointed out there is no circuit breaker to the electrics (fuse board...
