I've got 4 different sets of fixtures between our dining room and kitchen: 1 set of can lights + 1 set of pendants in EACH room. I'd like each fixture group to have it's own dimmer switch, all in the same switch box.
The source power comes in directly between the rooms with 12/3 nm cable (the dining room is branched from the red to create a separate circuit).
I'm trying to figure out the easiest way to switch all of these devices. Especially if there's a way where I don't need to run 4 separate 12/3 cables from the switch box to each group of fixtures. Wasn't sure if there's a way around that.
Thanks for any advice!
- TL;DR
- I need to put 4 different fixtures on 4 different switches; not sure if there's a way to double up on cable?
