Discuss Protek RCD Replacement??? in the UK Electrical Forum area at ElectriciansForums.net
S
Steve 82
Hi guys,
Need to replace a faulty Protek 63a RCD.
As most wholesalers probably don't stock this brand. Was wandering if a 63a wylex or another alternative would fit straight on the Protek din rail??
Would like to grab one from a local wholesaler tomorrow if possible.
Cheers
Just incase you havent sorted this yet, wylex will not fit as i have just been to try and replace a faulty Protek RCD 10 mins ago.
If you have sorted it, which make did you use please?
I believe both Geyer and Vynckier fit direct in Proteus, however their usually harder to source and more expensive. My notes also say Wylex and CFL? can be made to fit with a little bit of fettling. Be aware that mixing makes of protective devices in a consumer unit invalidates the manufacturers BS EN 60439-3:1991 Amt:2009 assembly type approval.
CEF stock the Proteck RCDs and CUs.
They are not that costly to replace.
If you cant find any let me know any I will happily sell you one.
Reply to Protek RCD Replacement??? in the UK Electrical Forum area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi all,looking for some pointers to an RCD problem, I work entirely on large poultry farms, I've only been in post a year, at some point before I...
