B
Brendan976
You probably have a loose/corroded earth and it is only showing up when you put a load on the circuit, bolt on a new earth cable to the battery and connect the other end onto the outer metal work of the lamp holder if this works you will need to identify the earthing points on the car clean them up. Now try again,but this time remove your temp cable, if this works jobs a good un if not get a copy of wiring diagram you will need to trace them out for continuity, disconnect battery but make sure you have your radio code first
Hth
Ben
Hth
Ben
