J
John Hardy
hi
on my normal headlight there is 13v of power soon as i connect the wire to the bulb power drops to 0 ?
On the off-chance that this isn't a wind-up: Is this while it is in the car, or are you testing the lamp on it's own? Daz
3 wires to bulb still in car ,earth wire ok , 13v on high beam wire ok and works when connected to bulb , but ? 13v on main headlight wire but if i touch the right connection on bulb it drops to 0v lamp if fine if i just put 2 wires straight to battery , just wondering why my live headlight wire drops to 0v when i attach it to my light but the battery live is fine
Do same test using headlight bulb from other side of car. Eliminate/home in on the problem. Do a resistance test on the bulb and compare to the other bulb. Let us know what you find and we'll go from there. Daz
both sides do it only way to make headlights work for now is to run a live to battery and a new switch inside and it works fine
just wondering while im testing it and headlight switch is on the wire shows 13v but soon as i touch the right terminal on back of bulb it drops to 0v i know its not the earth as my high beam works perfect
sounds like a poor connection 13V with no load, but as soon as you put a load on it, it drops to 0V.
Agree with Tel on this one, poor connection somewhere. Could be switch itself of course. Can you get any switch cleaner/WD40/etc. inside the switch? Daz
ARRRRGH... the dreaded fix all bugger it up spray.
i got another light switch stalk and still the same and replaced relays ? and fuses
- - - Updated - - -
if this helps it a mk4 escort loads of ppl with same prob but no answers
geordie spark is close to you. he's good with cars. he's got 3 that won't work. :speechless:
i dont understand electrics just basic . just wonder y it would say 13v but soon as i attach it to bulb nowt ?
