Discuss PVC cables buried direct in the UK Electrical Forum area at ElectriciansForums.net
Hi All
I was having a discussion with my colleague regarding burying a swa directly along with a pvc earth cable.
As the earth is not an armoured does this need to be ducted for mechanical protection and if so is there a regulation in the BS 7681 for it?
As above 16mm can be buried without additional protection
Silly reg thou as if 10mm needs protection from a fork or spade surely 16mm does as well
Yes I’m definitely not a fan of burying any cable directly myself as it is never sanded or dusted the way it should to protect against sharp stones although the consultant has specified it this way. I know swa can be buried directly but I am unsure of the regulation for non armoured cables buried directly. Need regulation to let the consultant know.
P198 and 199 of the BBB (brown)
Reply to PVC cables buried direct in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
