Discuss Pyronix Euro 46 v10 engineer code in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
planetf1
Hi,
I moved into a property 2 years ago with this alarm installed. I know the master code.
A few weeks ago I started getting battery warnings, and then constant panel beeping. At the time I looked for the engineer code in case a reset was needed after self-replacement of the batteries, but couldn't find it (default didn't work)
Ultimately the beeping couldn't be canceled, so I powered down the entire system (the external bell only lasting for <5 minutes)
I now have a choice to a) ignore the alarm b) use the original installer for maint c) Self-manage the alarm (it's bell only) d) find an installer that will do a one-off service and reset code
I'm inclined to go for c. My issue is figuring out how to (ideally) reset the engineer code or Possibly factory reset
Any tips on this panel? I don't see any nvram reset in the manual. I've read about a possible 2 finger reset once logged in with master, but not found details.
@planetf1 ,
Where abouts in the UK are you? There could well be a local member who can assist.
If you know who installed the alarm originally, it may be worth getting in touch with them.
When I install an Enforcer I get it setup so I can manage it from home using the Pyronix software... whoever installed it may have done the same and may be able to make configuration edits for you. There is a means of resetting the various user codes, but as best as I can tell you need to be logged into the engineering menu for this to work which is obviously no good. It may be worth giving Pyronix technical support a call, you may need the system ID which I think you can get from the master manager menu.
Reply to Pyronix Euro 46 v10 engineer code in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hello. Wondering if someone could give me some advice on my Veritas alarm. I recently had an extended power cut, when the power was...
Hi I have a scantronic 9800 control panel with Aritech sensors. One of the window shock sensors has a continual red led lit. The system is around...
I have a DSC POWER832 alarm with an LCD5501Z kepad and I'm 99% sure it's a PC5010 panel. And since I switched from DSL to Verizon FIOS...
Hi all, Brand new to the forums, I have a new Premier Elite 64-W and want to add a PIR to the hall as it appears to have been an oversight during...
