Discuss qualifications ??? in the Industrial Electricians' Talk area at ElectriciansForums.net
you generally have to be trading for 6 months as well as the two jobs etc
why not just use the LABC and not join a competent persons scheme until you are more established
thanks shakey
Shakey
I have a consumer change to do in a flat.Please explaine what will be the 1st steps about contacting the local council,do they visit 1st and i will be using the electrical installation certificate photo copyed out of the regs
go on their website and download their building notifiaction form or pick one up from them
submit it them along with the fee
complete job and send them a copy of the certs - they will tell you if they want anything else doing
Hi shakey
does the inspector visit before any electrical installation commences or do they check after inspection and testing and certification of the installation. are they sparks that turn up and do they just want a quick look at the work and want to check your test results.WOULD
Hi shakey
does the inspector visit before any electrical installation commences or do they check after inspection and testing and certification of the installation. are they sparks that turn up and do they just want a quick look at the work and want to check your test results.would
would they know a good or bad result on the test forms ie zs for a ring final being to high according to bs7671 17th ed
depends on you, depends on the job
I teach my students to build a rapprot with their LABC
many notification forms ask you your quals etc, obviuosly 'joe nobody', if doing the electrical work is going too come under more scrutiny than a fully qualified sparks
as regards paperwork, I teach people to fill it out as if mr 'top sparks' is gonna read it, personaaly i could spot a 'made up' certificate easier than i could spot Frank Bruno at a KKK convention
they may send someone in to check your work, they may not, much depends on you
as regard the 'inspector', there is no remit for him to visit before any electrical work commecnces, but if the installtion was part of a bigger building project, such as a new build, you can expect the normal building control visits at varying stages of the project, including a check of the electrics, such as a pre-plaster check
only form i can find on my local council web site is a building notice is that the one i need ? only other form is a full planning notice
yep thats right
it will generally be a building notice if it just an electrical job, it would be full plans for something like an extension (that included electrics)
I have had email from local council today and the will send local electrical contractor round to check work.price quoted on council site is £60.00 is this correct.On minor works do i submit test form to local council:)
Reply to qualifications ??? in the Industrial Electricians' Talk area at ElectriciansForums.net
Morning all, We are looking at qualification requirements for inspection and testing to BS EN 60204, all of our work is past the main isolator of...
Hi Everyone, I just move to UK and I'm a qualified electrician in Hong Kong. I tried ENIC to certificate my qualification which I have and ENIC...
Lads Can you tell me if there are any requirements for British Trained Electricians working in the Irish Republic ? Specifically, to do...
Good Morning, My name is Jorge I’m 29 years old and a Spanish electrical technician student at “IES San Marcos” technical college in Tenerife. I...
Due to demand, we need a qualified electrician who would like to teach. Suitable for all ages with a passion and patience, to pass on knowledge to...
