Discuss question about induction motor in the Industrial Electricians' Talk area at ElectriciansForums.net
S
subhpoto
How Current vary by increasing/ decreasing the number of poles of an induction motor?. in other word what is relation ship b/w number of poles and motor current.
I know that to calculate the synchronous rpm of a motor is
rpm = 120 x f/Np
to calculate the horsepower
HP = rpm x T (torque)/5252
and to calculate the current
I = HP x 746/V x Eff x PF
so by adding some values i have roughly worked out the following
with 415v(delta) efficiency of 90% and pf of 88% and torque of 4 ft/ib
(I1) 2 poles= 5.17A
4 poles= 2.593A
6 poles= 1.729A
8 poles= 1.296A
so as you can see that the current is inversely proportional to the number of poles, remember though you are also reducing the rpm with increase in poles
in this case the current after number of poles added (I2) =
(I2) = (I1) / (No of poles/2)
but then again what do i know...it could all just be bollox lol:D
Reply to question about induction motor in the Industrial Electricians' Talk area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hello, novice diyer here, but trying to learn more about electrical. I have done some basic wiring but that's about it. I have one of those...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
