Discuss R1 + R2 of ring circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi for a ring circuit, is there any need to measure and enter R1 + R2 values on a schedule of results ? Because an r2 value is already measured (together with r1 and rn). If I needed a ring R1 + R2 value to calculate ZS (although i would find ZS with a socket tester so really no need; but if I did) would i find it using the formula ZS = (r1 + r2)/4 ? Thanks all
Yep, values from testing are needed for your test schedule for both r and R. GN3 has method laid out in section 2.2.6.
I dont have GN3 yet unfortunately. On the test schedule (IEE model form) there is a column for r1, r2, and rn values, so its obviously a ring im testing. The next column along asks for either R1 + R2, or R2; R2 is long lead method which would give exactly the same value as r2. So with that in mind whats the point of recording an R1 + R2, or R2 value if you have already measured r2 ?? Which my question is, do I need to enter an R1 + R2 value if i already have r2 ?? If you get what I mean that would be great ;)
Def recommend GN3 ... I do tests and enter values for r1, rn, r2 and (R1+R2). Then I compare (r1+r2) to (R1+R2), looking for the magic 4 factor if I've built it right :)
With r1 r2 rn you confirm that it is RFC by doing R1+R2 you verifying that cpc is actually connected to the socket and as jackhammer said verifying polarity
It certainly shouldn't if done correctly! In fact it should be a quarter of the r2 value if there are no spurs. But given that the test for the (R1+R2) value is required as part of the ring final circuit continuity tests I see no merit in opting for R2 over (R1+R2) presuming that we are discussing initial verification here.
Okay, so in step 3 of the ring final test, when you cross connect L + E, the highest result is your R1 +R2. Having a brain drain today, quickly why would R2 differ from r2 ?
Pete demo one of your videos quick.....
No sod it I am going to revert to lyrics from the great man, all together now:
Has he lost his mind
can he see or is he blind?
Is he alive or dead
Has he thought within his head?
Sorry been at the home brew again
Come on FFS
Is he alive or dead
Come on FFS
Love it
Is he alive or dead
Come on FFS
Been on the red and she relented and poured me a nice slug of Single Malt could be a bit tender in the morning
What was it?? You tried any of that Welsh stuff yet??
And how do you get your Mrs to "pour me a slug"?? I just get "I thought you were having a night off it today?"
I'm with @Hellmooth and @Pete999 on this one - your RFC testing is a 3-stage process. r1, r2, and rn values are pretty meaningless without a valid test in the other two stages.
@jackhammerJIM R1+R2 doesn't prove polarity on it's own. If you only carry out R1+R2 you would not see a L-E reversed. You need to carry out an R1+RN as part of the process which will then fully prove polarity.
r1 resistance of line, r2 resistance of cpc, rn resistance of N conductors
R1+R2 resistance of the circuit at furthest point, in a ring though should all be the same (every point)
Zs = r1 + r2 / 4 is not right
Zs = Ze + (R1+R2)
Is he alive or dead
Come on FFS
See Mate I relented, couldn't resist, did 2 vids just to be sure hope you like it (for sparksburnout) may try and find some of that Welsh gear you are harping on about, :p:oops::)
thought harp was irish (guinness). :mad:
I thought Harp was a lager from the 80s. I remember the adverts - 'Harp - Stay Sharp, to the bottom of the glass'. Christ, why do I remember crap like that! Daz
Harping on (you know going on about something) crikey wish I hadn't bothered, but I aint going to harp on about:mad::oops::p:)
I remember that, tis from Ireland though.
Must be an age thing, I always seem to recall such rubbish during monotonous periods.The people who come up with these buzz lines obviously know what they are doing if it stays in your memory! Bounty, a taste of paradise.......
While we are off piste so to speak anyone remember Double Diamon, or Red Barrel??;)
I remember some idiots in my youth drinking lager & blackcurrant :eek:
I also remember going to the pub for the first time with me mates at 14, having a steak and 3 pints of Tartan and threw the lot up. Think it was a bad steak :rolleyes:
Reply to R1 + R2 of ring circuit in the UK Electrical Forum area at ElectriciansForums.net
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
So I’m doing my level 3 design project at the moment, and I’m on the question where you do all the calculations on each circuit, I’ve taken the...
Evening all, Having a debate with a colleague about using the SWA armouring and a separate conductor both as CPC's for a circuit. So in theory...
