O
This board is a Crabtree SB6000 Starbreaker with the standard copper finger busbar and screw fixed protective devices (pre plug-in Starbreaker). The only RCBOs available for these early boards are 2 modules wide, looking like an MCB with an RCD stuck on the side. The MCBs and RCBOs for SB6000 boards were available in Types 1 and 2 only.
I realise this is a little late, but I am looking for exactly the same (although 32A rcbo) and came across this which would fit your CU. If you have already solved the problem I'd be interested to know what you did?
NEW Crabtree Starbreaker SB6000 6 Amp RCCB Type B 6Amp 30mA Breaker 6A RCBO | eBay
I doubt it's "NEW" :cry_smile:
Its not! Can you get new RCBO's that fit this CU?
