Discuss RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not aware that one RCD has ever been the norm?
Then you never lived in my part of the world to see in the early seventies
If there happened to be any sort of circuit breaker it would have been a voltage operated elcb
The Rcd that replaced these were fitted to almost every household electrical system that existed in that location
Quite.
Loads of houses on a TT supply with one upfront ELCB or RCD.
If total loss of power is regarded as a significant safety issue, then emergency lighting or an automatic-start backup generator should be installed to cater for power cuts. Or a UPS fitted to specific items of essential equipment.
Err how can a bedside be used and how can the sockets not be affected ?? The point is the rcd is the main isolator switch and also controls all circuits !
Talking about a dual rcd db and that you can have up lights on one rcd and up sockets on the other thus if rcd protecting up lights trips then at least a bedside lamp can be used on the upstairs sockets so there can be some light.
Read it again!
Picture of one such installation I visited
Just today
I'm lost!
I was referring to a dual rcd consumer unit I would have to go and read through the entire thread again to see what context I brought this up with.
Hope you commented on lack of circuit identification tho :)
I've never ever used RCD's in a domestic installation. Split load 2 RCD boards are not for me! 100A main breaker/isolator with RCBO's is the only way. AMEN :eek:
Reply to RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
