R
rad1o
We have had a split load C/U installed about 5 years ago. We have always had some tripping often when electric motors were started like lawn mower, drills, grinder. We had the unit tested and the electrician could not isolate the fault, but found that there was continuity between the lights and a socket ring. All tests were fine.
I have been reading about RCD tripping and have read the advice to change the RCD to an RCBO. This seems a more sensitive device than a RCD. Would this not cause more tripping than we already have?
