Discuss RCD Protection for lighting within communal parts in the UK Electrical Forum area at ElectriciansForums.net
I'm due to start working in a building which houses lots of flats over 6 floors with 2 internal communal stairs. I'm due to replace 13 ceiling lights per floor/stairs from a halogen bulkhead to a ELD 17w LED microwave/emergency bulkhead.
Each floor is fed from a Square D B6 QOE MCB on a 3 Phase board.
Regulation 411.3.4 requires that all luminaries within domestic (household) premises are to have additional protection by a 30 mA RCD when installed in an AC final circuit. Note that the regulations refer specifically to "domestic (household) premises"
My question is, would you suggest that these bulkheads require RCD protection? I suppose its up to interpretation of the regulation, although they are within a domestic environment under Part P and the Building Regs would you suggest that the communal parts constitute a "domestic (household) premises".
The only RCBO's that I can find that are compatible are £60 a pop and ill need around 10 of them otherwise i'd just stick them in anyway.
It’s the circuits which require RCD protection not the lights.
It’s the opposite to sockets.
If you were to extend or alter the wiring, then yes RCD protection would be required.
Reply to RCD Protection for lighting within communal parts in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
We have started a business building garden rooms/caravans/mobile homes under the caravan act. We have only done one so far and I got an...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
