Search the forum,
Discuss RCD protection for PV? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Formal qualifications and experience :)
EH ERRR
Sorry Gary but that was my point,
The regs make no reference to formal qualifications in their definition of competent only technical knowledge and practical skills are enough to qualify as a competent person.............apparently.
Thanks very much for your help guys.
The supply was TNCS with good Ze, so I used a Garage unit with 20A MCB and a built in generationn meter.
EH ERRR
The regs may not, but the courts will. In the event you have to defend yourself in court you would be expected to provide evidence of competence.
Training+qualifications+experience=competence
we discussed this at length on here before, as my understanding was that transformerless inverters needed RCD protection, but it was pointed out that most transformerless inverters (SMA, FRONIUS etc) have inbuilt protection that meets the need for automatic disconestion that would require the need of an RCD.
do you know where we can find information as to weather SMS for example, has built in protection negating the need of an rcd for the tl range?
Guys that have ended up in court in the past have sometime found that despite having the training, qualifications and experience they are judged as incompetent and locked up. As we see on here you can do your best, do what you believe to be right and someone will still drag the **** out of you. Get two "experts" together and it's Harry Hill time.
very true. Whenever 2 or more electricians are gathered together there will be an argument about the regs! (just see some of the posts on here :0) )
SO- get yourself in court with 2 'expert' witnesses and if their interpretation is different to yours your in the mire.
Your own credentials are part of your defence though. Try standing up in court and saying, 'well actually I don't have any qualifications and this was my first install' and they probably won't even need those witnesses.
Reply to RCD protection for PV? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Is it ok to have PV system into shared (household) RCD? So I've had a system installed, but not yet complete/signed off. The issue is that the PV...
8K
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
