B
beaver74
evening all
what tolerance do you put on you D_lock tester
as i have had my MFT52 calibrated and it reads a differance of .30 when tested standard E loop And D_lock E loop tester
testing on same no RCD protected socket and this socket is my test log socket and readings have been the same since i started to log them and before it was calibrated
your views please
