C
Chrisknowlesuk
Hi
I have an issue with random RCD tripping. It happens at different times of the day and no obvious cause (ie particular piece of equipment).
All connected equipment has passed recent PAT test and IR on circuit looks ok (>600M PE).
A lot of the connected equipment has thermostat controlled heating elements - wax melting machines etc (it’s a beauty salon).
Had a thought that if a couple of RCD protected socket adapaters were put on the sockets and checked whenever it tripped, Does this sound like a reasonable albeit long winded way of narrowing down the fault??
Any other suggestions??
if you are thinking of the plug in type, you could get some 10mA ones. if it's appliance problem that would sort it. as long as you can rely on hair-brained beauticians to plug them in.
Will achieve better discrimination that way. Good idea.
I would ask the customer to keep a log of when the tripping occurs.
What's the background leakage on the circuits protected by the RCD ?
You could have high leakage and anything could tip it over ....
What are the RCD test results?
Have got s couple of 30mA plug in RCD adapters, hopefully they will still work.
Haven’t run tests on RCD in board yet.
Been promised free Manicure and spray tan if I cure the problem....
Hmm... unfortunately not, otherwise payment in kind..
As for spray tan and manicure I was only kidding - my finger nails are past it!!
For us to be informed on the installation could you also tell us:
1. the type of earthing system.
2. presence and state of EP bonding.
3. computer equipment?
4. any water leaks recently?
5. what kind of lighting?
6. how for example the wax baths are supplied.
I'm not sure you could guarantee discrimination using that method.
Just out of interest,has anyone else tested any of these plug-in RCD adapters? I did,on one me dad had purchased from B&Q and the best description i could give it,would be "random" :)
You mention
"All connected equipment has passed recent PAT test and IR on circuit looks ok (>600M PE)"
Have you done a NE insulation check?
