Soulsurfer
612
165
118
Channel Islands
Business Name
M.B.S ELECTRICAL
Hey all looking un-successfully for a downlight style recessed wall washer just like the Robus Wilson model which can angle / tilt down up to 45 degrees to flood wardrobes, the robus unfortunately is only in white and they want satin nickel, brushed steel kind of thing to go with the steel downlights in room.
Anyone got any ideas ? need to be nearer the 45 degrees as took an Enlite one but it only tilted to 20 degrees and not enough to hit wardrobes, must be LED and really fire rated too or at worst MR16 and I'll get an LED lamp to fit.
Perhaps the Saxby scoop downlight, fully adjustable and available in satin nickel, but I do not think it is fire rated and you would need an MR 16 LED lamp.
I am not sure you would get any fire rated downlight that can adjust like that as the motion is too great to enclose, you would have to use a fire hood (gosh, there is actually a point to fire hoods!)
Reactions: 2 people
Hacel do some good ones, I think it's the Aleda. It might be worth having a look at Luceco and Taison as well.
As much as I normally dislike Tamlite, I've found they're adjustable downlights the best looking I've seen by some distance. Look almost identical to an MR16 fitting of old, fire rated, dimmable and tilt to around 35-40 degrees I'd say. You'd have to go to CEF to buy them though and they're not cheap. £30 plus iirc.
http://www.starlite.co.uk/pdfgen.php?productCode=50408
Soulsurfer
Channel Islands
Business Name
M.B.S ELECTRICAL
Recessed wall washer ??
Electrical Appliances & Whitegoods Forum
Soulsurfer,
mattg4321,
