Discuss Reg no for main switch on tnc-s in the UK Electrical Forum area at ElectriciansForums.net
bigspark17
Should main switch on tncs isolate all poles.? Switch in the pic only isolates the three phase conductors!
Reg no?
There is no requirement to isolate the neutral in TN systems as far as I know except for domestic situations where the switch is intended for use by householders.
Andy correct as always :)
537.2.1.1 - says for TNS and TNCS its not required to sw neutral
537.2.1.7 - provision of a way to ISO neutral must be provided (a link)
537.1.4 - single phase domestic both L & N to be sw.
I looked for ages at this picture for the main switch Bigspark. Then I saw you pointing at it. :):)
I think he's actually pointing at the sticker posted by the NICEIC contractor that appears to state an installation date of June 2014 and recommends the next test date as June 2014. Maybe not very confident in their work ....... lol.
A least they're not responsible if something goes wrong a couple of days after testing Andy.
Past its retest date.
Reply to Reg no for main switch on tnc-s in the UK Electrical Forum area at ElectriciansForums.net
Hi all, if I cannot access the line side of a crabtree 100A DP main switch. Would someone enlighten me how to conduct safe isolation on this...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
