Hi,
Just after a little advice really - i am currently undertaking a complete home renovation.
I have a really ugly looking Plastic CU on the wall as soon as you walk in the house which I am looking to relocate ideally under the stairs
There is a single rated meter installed inside the Electric Box within an enclose brick building attached to the property - see the picture.
I have purchased a Wylex Switch Fuse which i understand if this is installed cable from the switch fuse can then route to the new CU which is a Schnider Easy 9.
The intended route of the cables from the switch fuse is through the joists what cable is suited for the run through the joists?
Also can the S/Fuse be installed within the Meter cabinet?
