Discuss Replacing 2 gang switch for another but has different terminals in the DIY Electrical Advice area at ElectriciansForums.net
I'm looking to replace old 2 gang switch for a new one.
2 separate lights and one is also controlled by another switch.
Old has 4 wire holes including loop?
New is what I'm used to seeing.
Any ideas on how to wire up?Screenshot_2023-03-15-20-33-31-71_40deb401b9ffe8e1df2f1cc5ba480b12.jpg
Can you actually show a pic of the existing switch terminals whilst still connected.
Your new switch doesn't have the Loop terminal so they need putting into a separate connector away from the switch then connect the other wires in the same numbered terminals. The earths need connecting to the earth terminal.
They are neutrals in the Loop and I think that terminal is unique to Hager. It isn't actually connected in any way within the switch it is just a convenient way to connect the neutrals.
Schneider do a loop terminal too.
Has thrown off at least one DIYer tried to change his own switch…. This is supposed to be a 2 way.
I actually really like the Hager switches for that feature - it's almost like someone has thought about what we actually have to do.....
Reply to Replacing 2 gang switch for another but has different terminals in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
I'm just replacing a 2 gang switch that controls the two ceiling lights in the living room with an updated one and I'm puzzled about the current...
Hello, I wish to replace the old 2 gang switch pictured, with the smart switch pictured. Am I right in thinking that all 3 reds wires would need...
