Discuss Replacing a Lutron Maestro MA-LFQ35 Light + Fan Combo Switch in the DIY Electrical Advice area at ElectriciansForums.net
Dave50W
Greetings!
We have a ceiling fan with a 4-bulb light fixture. The fan switch of the original Lutron Maestro MA-LFQ35 combo switch quit working, but the light side continued to work, including dimming. I could not find the same switch online, and went to a local electrical / lighting store where I was sold a Lutron Maestro MA-FQH-WH switch. I installed the switch, but is does not work. I contacted Lutron Help and was told that the new switch needs another circuit added between the fan/light assembly and the switch. The challenge with that is that the assembly was installed during home constructin over 20 years ago and there is no was to add another wire.
I just need a switch to replace the LFQ35 that will use the original wiring. I want to maintain both the dimmer on the lights as well as the speed control on the fan.
Any / all suggestions are greatly appreciated!
- - Dave
Greetings!
- - Dave
Follow - Same situation. If you found a solution, please share. Thank you!
Reply to Replacing a Lutron Maestro MA-LFQ35 Light + Fan Combo Switch in the DIY Electrical Advice area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Recently moved into a new home. My bedroom has an old Lutron light/fan switch combo that I want to replace with a smart one (it's adjacent to...
hello all, pardon my ignorance in not employing an electrician, however, im a diy'er whos changing the light switches in my house and came across...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
