• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
@Santa in response to your original post, i assume that since you live at the north pole it would cost too much in diesel for us to come have a look and fix it for you, so if you go down the chimney, stop half way down and you will be able to come through the wall with a sds drill and scutch chisel. then replace the offending part.
Or you could get Prancer to stand close by and use him as a step up.
