Discuss Replacing wire in a fuse? in the UK Electrical Forum area at ElectriciansForums.net
Ccx295
Hi all,
This is the first time which I have had to replace the wire in a fuse so I just want to make sure that I have done it correctly.
The wire which I have fed through the two holes is not perfectly straight where you can see it through the opening, is this ok? (slightly bent)
No it should not be a problem, have you fitted the correct size of wire. Do you know why the fuse blew as it could be hazardous when replacing the new one if you have a fault on the circuit.
Thanks for the reply. 5amp (upstairs lighting)
Yes which I am now trying to figure out. Our spare room which has 3 spot lights are all not working.
I have removed one bulb which is a 12v so I assume there is a transformer somewhere? is this a job for electrician and is it safe to now have power back upstairs with these not working?
as long as you have fitted 5A fuse wire, should be OK till your friendly local sparks arrives to trace the fault and ensure the circuit is safe to use.
If they are the only ones not back on I suspect one of the transformers has gone so leave them switched off.
Where are you located?
Reply to Replacing wire in a fuse? in the UK Electrical Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
