Discuss Resistance per meter of armour in the UK Electrical Forum area at ElectriciansForums.net
I know it's late and the lap dances are still open , so i will wait till tomorrow for any replies . Does anyone have resistance per meter tables for steel armour 90degree thermosetting ,can't find it anywhere . Ta
Early to bed, early to rise makes Sparky healthy, wealthy and wise ... Why did I not listen to my Mum?
Anyway, I don't have one but here's my suggestion ... using the table below first column for Steel mm2 divided by the resistivity of st/cu taken as 8.5 (from GN8 p60) should give the Cu mm2 equivalent. Don't use the table Cu values in the table (it's for CPC and uses k not resistivity). Then convert that to Cu mm2 to resistance using 18.1mOhms/m at 20degC for 1mm2 (OSG Table I1 page 190). But it is early. Hope that helps :)
file:///C:/Users/Pete/Desktop/SWA%20CPC.pdf
Is this what you are after? good job some of us "Old scho;; brigade" are on the ball cheeky b-----
Reply to Resistance per meter of armour in the UK Electrical Forum area at ElectriciansForums.net
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
I'm a homeowner. My flat came with a prepayment meter. I was due to get it changed by Green Network Energy. I even specifically chose them...
