Discuss Reverting from LED lighting to Halogen in the Lighting Forum area at ElectriciansForums.net
I just had a look at some of the evidence about these effects
What I can gather from reading the info is the headaches are a consequence of on/off moments hundreds of times per second by the led
The dimming of the led is 100%, compared to that of 35% for a fluorescent tube
These off moments if too slow are seen unconsciously by the eyes, the more this cycling is increased the less its perceived
It suggests the better quality Led will cycle quicker than the cheap and nasties out there
Perhaps there may then be less chance of the human eye detecting these off periods
Seems to be a problem that has not been catered for when too readily ditching older technology prematurely
The only problem with halogen GU10s is that they are a little prone to blowing more regularly. And obviously they cost a bit to run.
Is it that the lights flicker Jennifer or is it the stroboscopic effect you are getting? Some people are more prone than others to this phenomenon. If they are flickering they shouldn't be and something is wrong. If it's the strobing then more expensive LED lamps will likely be designed better to counter the AC waveform issue Des mentions above. You could try a couple of the more expensive lamps in a bathroom perhaps where you wouldn't need to replace 8 of them.... And see if that helps.
I do feel quite strongly in favour of LED technology, so would encourage you to try out a couple of decent ones before you give up on them..
If the downlights are dedicated LED Units, replacing the bulb (or lamp if you prefer) won't be an option. I agree with @Murdoch in post #2. Get a spark round to take a look.
Thanks, I've written to an electrician. I do see that testing some others is a good idea, but it takes me a long time to recover after exposure to LEDs. I still have a headache and other trouble since exposure yesterday and don't feel at all enthusiastic about testing more. Yuk.
think i'm going to need to contact Jack Daniels in Tennessee. his whiskey must be LED as it gives me a headache after every bottle.:D
Jen,
Personally I wouldn't just dismiss the idea of LED lights. There are (as mentioned) some variables to consider first before you swap back to the halogen lamps.
1. Make sure the dimmer switch is functioning as it should
2. Swap out the dimmer for a better quality or a normal switch
3. Change the lamp colour from cool to warm or day light.
4. Change the lamps for better quality ones (there are many different makes and qualities out there and to be frank some are sh**.
The down side of using halogen lamps is that they are more costly to run, get hot and need replacing more often.
Reply to Reverting from LED lighting to Halogen in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
