Deleted member 112675
Since it was so quick to do, I decided to try Wilko's kind suggestion. I've only done the easy first part partly because I know it is a ring (its in my house and I've seen it) and partly because I just wanted a sanity check before doing a load of other work and then a final test.
Anyway, the numbers around the ring in ohms were:
L 0.18
N 0.17
E 0.41
This is 2.5mm twin and earth.
That last reading was higher than I would expect since I think it should be around 0.3 but not sure if its anything to worry about. Perhaps my earthing terminals are not as tight as the others.
L 0.18
N 0.17
E 0.41
