B
Brian Read
My neighbour has a problem with his Securoglide Compact electric roller shutter door. When using either the wall mounted control box or remote control it closes OK without any problem but when attempting to raise it using either controls it stops after a few seconds and starts again intermittently.
He has been quoted nearly £600 for a new motor but I'm convinced the problem lies with one of the relays in the control unit., which alters the polarity and changes the rotational direction of the motor of the motor and flashes every time it's activated, and the motor stops..
Can anyone tell me if the relays are plug in type or PC mounted before I investigate it further?
Any advice or suggestions welcomed
Thank you
Brian
Thank you
Brian
