Discuss Running 10mm T&E externally? in the UK Electrical Forum area at ElectriciansForums.net
Galv seems a bit excessive for domestic, but depends on budget I suppose.
Have you considered using NYY? I love the stuff: a bit dear but dead easy to install (unlike SWA) and it knocks spots off T&E.
You could do the whole run in NYY - no need to change cable types, and being solid core not stranded like HO7RN, it's easy to terminate at both ends.
I've just used some 5-core 16mm NYY for a sub-mains in my own house, where I'd have used SWA before. I'm converted! (Obviously in an area not liable to mechanical damage.)
Reply to Running 10mm T&E externally? in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
Hello ladies and gents , Simple question , where in the regs book would It discuss or what does it say about clipping direct 1.5mm t&e in the...
I have a TPN board that will feed 8-10 sub boards. The loads on each board are negligible 5-10 amps peak but mostly 1-2 amps. The distribution...
