Im installing floor insulation and want to attach 2.5mm2 T&E to the galvanised mesh supporting floor thermal insulation. At the top it will be touching 175mm of rockwool insulation, at the bottom it will have between 100 and 150mm of air space (as seen on attached photo). Question: What installation method would that be considered as? Will cable capacity be reduced to the point that I need to amend anything? This is a ring circuit with 30A breaker supplying living room and dining room
