Discuss Running 2 Metal Containers with a generator in the UK Electrical Forum area at ElectriciansForums.net
S
Stashton1990
I have been asked of my club to wire up 2 cabins with power so they can have lights on during the dark mornings. There is 3 metal cabins in total one with a generator in it, one which is the main office and one for meetings. The 2 cabins that want power both have a C.u in them. So if i wire in a 16amp 230v external socket to each of the cabins so they can plug the generator in when they arrive in the morning.
How would i go about earthing them. Would i put and earthing spike in and wire each cabin and the generator back to the spike individually or would i give each cabin a spike each?
So 3 metal containers/cabins. One has generator the other 2 are occupied by people.
You say they have CUs. All of them? Are the all connected?
What's the current cabling between the 3 cabins and how is that related to the
You need to put a plug on each cabin, not a socket. The socket will be connected to the generator.
Is there an N-E link in the generator? Is the generator frame in contact with the metal parts of the container or is it isolated from it, if it is will it remain so?
I suspect that you will need to install an earth electrode of suitably low resistance to create a TNS system.
Reply to Running 2 Metal Containers with a generator in the UK Electrical Forum area at ElectriciansForums.net
Currently I have a Henley block which has 2 consumer units. 1 of these CU feeds a garden supply and garage. Out in the garden which is fed by a...
Hi everyone need help pls I need to power 2 x portable work cabin The meter people came today installed new supply with one meter 25 meters away...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
