Howdy all,
Looking for some opinions/advice Ime planing out a job for putting power in my shed.
Plan is drill through a socket on the ringmain in the living room wall to the outside, Fit a IP66 FCU with RCD protection, Then off that to a IP66 double socket, then onto my shed with SWA for another socket and light.
Nothing to hairy.
But I was thinking of the best way to join the FCU to the SSO in terms of keeping them watertight as they will be obviously be open to the elements.
So I was thinking of using these:
Masterseal IP56 PVC 20mm Conduit Entry | Outdoor Cable Entry | Screwfix.com
Out the bottom of each unit and then have a bit of 20mm bent between them.
So heres my questions:
Firstly do the above seals work with any 20mm knockout or will the only fit the MK range as Ime planing on going with BG stuff to keep the cost down.
Secondly in terms of drilling through the external wall is there a minimum height to go past to avoid any damp course etc as I cant see any membrane or anything like you sometimes do (house was built around 98 if thats any help) Also what about sealing the hole back up around the T&E cable?
Best to use silicone or just put some mortar around it?
Cheers all.
Howdy all,
Nothing to hairy.
Firstly do the above seals work with any 20mm knockout or will the only fit the MK range as Ime planing on going with BG stuff to keep the cost down. never had any problems with bog standard adaptors into bottom of enclosures.
Secondly in terms of drilling through the external wall is there a minimum height to go past to avoid any damp course etc as I cant see any membrane or anything like you sometimes do (house was built around 98 if thats any help) Also what about sealing the hole back up around the T&E cable damp course is at floor level so you should be well clear at socket height.
Best to use silicone or just put some mortar around it? silicone or mastic.
Cheers all.
my comment s in red. drill through wall 20mm and tube through. open the outside hole to25mm to accommodate the elbow.
Cheers Tel,
I wasnt going to bother tubing through the wall just a T&E straight into the back of the FCU, I was then going to Tube between the FCU and the SSO and then Tube the socket and lights in the shed. Oh and the outside light that will be on the shed LOL
if you're going into the back of an outside FCU, then you need to seal round the FCU to stop wet getting in art the cable entry.
20mm tube through wall in 20mm hole. have the tube protruding into the FCU by 1/4". after fitting, seal round top and sides. sssimplesss.
As a matter of interest, why are thinking of using a RCD FCU, isn't the socket circuit you are coming off in the house RCD protected at the CU??
Yes it is RCD protected.
And its actually cheaper to get a RCD unit than non RCD surprisingly.
Although I just managed to get a good price on a MK masterseal FCU and DSSO so ile be using then instead :)
Telford
Running Conduit into outside sockets.
Tiny Spark,
Tiny Spark,
