Discuss Running Submains with general lighting and power??? in the Commercial Electrical Advice area at ElectriciansForums.net
J
John Matrix
Hi everyone I have an issue that I need some advice with. I have been asked to fit a panel board in a basement to some offices. From this I need to feed another distribution board. This board is feeding some general lighting and power. My plan was to link everything with a 100x100mm metal trunking and then run tails through the trunking from the panel board to feed the distribution board. I have been told that I should be keeping the tails and the general lighting and power circuits in separate trunking but I can’t see an issue with running it in the same one. Is this ok or do I have to run it separate?
What plank told that?
There is no regulation requiring this, however if you have a specification which requires it then you should follow that.
You don't get fired for doing what the boss has told you to do, but going against his instructions could be a different story
Not sure if this is a thing or not. Is the separate trunking for the lighting purely for the emergency lights?
Not sure why it would be...
Well I’ve put all my brackets In ready and now it’s gona add 3 days onto the job. 3 days we ain’t got. Oh well. Smile and wave.
Ask your boss why they need to be separated as it's not in the regs. See what he says.
Reply to Running Submains with general lighting and power??? in the Commercial Electrical Advice area at ElectriciansForums.net
Evening, I've been asked to install a supply to a sprinkler system in a new installation that must be separate to the building electrical...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Hi, I have run some outside lighting for a customer in Hi-tuff cable. He now wants 2 additional lights run across scaffolding which has been put...
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
