Not really but thought there might be some deals lurking about in the sale
I will see what I can find and post it up on here.
[automerge]1569686825[/automerge]
Not really much in offer. I may try eBay and see about a kit.
Discuss SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Hilti all the way!
Hilti all the way! Although the price is a lot more it will outlast the other common brands and the service provided is second to none. My sds was 4 years old at the time and developed an intermittent fault. It was picked up, fixed and back at my door within 4 days and cost me £25 for the repairs!
I would love Hilti but I dont have it, maybe when I am fully qualified and earning the big boys money, I can look at it.
brill.had combi and impact for 11 years. had to replace motor in combi but that was due to abuse.4"hole saw in cement board. took all the teeth off the saw, took 25minutes to get through 8mm.@telectrix how do you find the AEG gear? Don’t think I’ve ever seen one in the flesh.
Milwaukee looks good. Is the M18 Fuel range good? As I’ve found a Combi Drill for £250 online brand new. Should be £350.
Or would this be better:
Milwaukee M18SET2B-513B 18V Li-Ion Cordless Combi Drill, SDS Hammer Drill & M12 LED Torch Kit 2 x 5.0Ah 18V & 1 x 1.5Ah 12V
Milwaukee 3 piece kit: • M18BPD 18V Li-Ion Combi drill • HD18HX 18V Li-Ion SDS Hammer drill • M12TLED Torch • 2 x 18V 5.0Ah red Li-Ion batteries • 1 x 12V 1.5Ah red Li-Ion battery • Charger and carry case M18BPD 18V Li-Ion Combi drill • High performance 4-pole motor • No load...www.toolstation.com
I’ve also seen this Dewalt for £200 online:
DeWalt DCK266M2T-GB 18V XR Cordless Brushless Combi Drill & Impact Driver Twin Pack
When you're faced with a task involving lots of different surfaces, choose this brushless twin drill kit comprising a combi drill and impact driver. This package comes with two 4.0 Ah Lithium-Ion batteries for minimum downtime on the job, as well as a multi-voltage charger and kit box to...www.toolstation.com
I have this dewalt pair, since February 2017, have a spark and apprentice working with me, so get plenty of use and still going strong, also have the 273 model sds, again no issues, bought at same time.
Also dewalt comes with a 3yr warranty too.
Mate has the M18 and it feels alot heavier than the Dewalt, and the chuck doesn't stay grippy for long, which makes it difficult to open to release drill bits, also their sds quarter turns to release bits, whereas the Dewalt us pull bavk to release.
Apart from that I don't believe there is any difference, heard they both use same motors and batteries, if that's true or not I don't know.
i have... ... bin/skip.Would you have any recommendations for a Dewalt SDS?
had a dewalt 24V sds. less power than a £50 aldi cheapo. then it died trying a 12mm hole in a bit of brick.Not a fan Tel?
they must have improved then. mine was pre Li-Ion. metal halide or whatever. i retract my comment if you'll retract your not cool.That must be a long time ago Tel, my 18v does 25mm holes with a metre long bit and a bit of light tracking work too, and can't fault it, at times I consider buying another body only for when we are busy.
comment retracted. apparently deWalt are OK these days.i have... ... bin/skip.
Reply to SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
