Discuss Setting or adjusting a Horstmann Astral Clock in the UK Electrical Forum area at ElectriciansForums.net
A friend of mine has an old mechanical Horstmann Astral stair lighting timer. It has managed to get completely out of whack in both times and month.
Anyone know how to adjust or reset one of these clocks? Can’t find any instructions other than “don’t mess with these things, live electricity, very bad, get a professional” I just want to know how to set the month, date and time on this thing.
Any suggestions?
They're simple enough to set up.
You just have to wind it, clockwise as per arrows, manually through the months till it's showing the correct month and time.
Don't over do it otherwise you'll end up winding it almost a whole year extra.
The day you have to guess.
Currently it looks to be at 10.am on the 22nd October (about 3/4 through the month)
Reset was not an option on mechanical clocks.
Reply to Setting or adjusting a Horstmann Astral Clock in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have quite an old Horstmann Economy 7 Quartz water heating system in my flat (installed around 2007). It's been working fine until the...
5K
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Hi there I’m new here and hoping I’m posting in the right place. I am a homeowner with little electrical or heating knowledge. I have a room...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
