And then the poor who next does an IR won't see it and wonder why the L-N is pants!
Last time I did domestic a shaver unit was switched on by the plug pins moving the shutters and operating a micro switch.
Therefor not in circuit unless in use?
Boydy
course it's still a circuit. what about a socket that's switched off... dummy.
If it was me stick an leisure battery underneath the floor, then attach a small inverter and power it, that way when the battery runs out they'll call you out to sort it! :smug2: Hehe.
Anyone considered the makeup of a shaver socket....theres a little transformer in there, just like the big yellow ones we all used on site...!!
Most shaver sockets are dual voltage....so take you pick blue/yellow....used yellow as general suggestion of earth isolation
For the benefit of the OP. the safest way is to tap of the lighting circuit....the max load of a shaver socket is 200-250w ie 1 amp. Saver sockets were designed well before rcd & rbo, to provide isolation from earth via a transformer, the idea as on building sites is to isolate the earth so and electric shock can not occur buy touching either line conductor. the output at either 110v 0r 230v is l1 & l2 there is no neutral .....hope this helps
No body has mentioned low voltage, we are talking abaut isolation of earth potential via transformers...??
He is correct Tazz, therefor my mention of a 230/230 blue, isolating tx.
Yellow 110v still 55v to earth,
Boydy
No there is no center tape here......consider a 1;1 transformer....230v in 230v out .....live and neutral in.....now the output is L1 and L2 , the earth potential has been removed, hence there is now no neutral on the output.
Agreed.
I think he was just picking up on your mentoin af yellow site tx in post 20.
Like i said, agreed.
Boydy
