Discuss Shower 8.5 on a 40mcb is it dangerous in the UK Electrical Forum area at ElectriciansForums.net
Do you have some work that needs doing, some plug tops installed perhaps?
Could get the Part P Qualified Spark to look at installing some LED Bulbs as well when he/she is there.
All my plugs have their tops on.
As I said there is NO SUCH THING as a part P qualified spark.
Bulbs does not need an upper case letter in the middle of a sentence.
Your idea of taking the *iss is not amusing.
If you think the term 'Part P Registered' is bunkum, take a look at these search results:-
part p registered - Google Search - https://www.google.com/search?q=part+p+registered&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjk_ri9_ezgAhUSVBUIHeISC4sQ_AUIDigB&biw=1920&bih=903
Part P Registered is a phrase from the schemes and is used it seems to promote sparks who are registered with them who can carry out notifications. After all, Part P is the section of the building regs that requires us to notify, so the term 'Part P Registered' get's used to indicate a particular company can notify.
The Part P exam is C+G 2393, with the proper title being something like 'Building Regulations for Electricians' or words to that effect. But in common parlance it often gets called 'The Part P exam'.
It is NOT dangerous, it is correct.
What would be dangerous is putting in a 32a MCB as it could overheat.
Why would a 32A cause it to over heat and not a 40A as fitted. Surely the issue is whether the cable can take the current? If this is running at over 32A and the 6mm can take the current based on length and installation 40A must be correct? 32A wouldn’t cause overheat it would just trip.
Why would a 32A cause it to over heat and not a 40A as fitted. Surely the issue is whether the cable can take the current? If this is running at over 32A and the 6mm can take the current based on length and installation 40A must be correct? 32A MCB wouldn’t cause cable to overheat it would just trip.
You are right, the cable loading is still the same. It's the 32A mcb that will likely be running a bit warmer than a 40A mcb, with that 35A load. Neither MCBs will trip with that load, unless teenagers are involved.
if teenage daughters are involved, I'd fit a 20A. soon get the buggers out of the shower when it goes freezing cold after 2 minutes.
And BS1363 plugs have been called plug tops as far back as I can remember.
I started calling light bulbs - lamps, after comments on here by members But then my customers thought I was referring to luminaires, which they call light fittings; so I went back to using he term light bulbs. :)
Reply to Shower 8.5 on a 40mcb is it dangerous in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
