Discuss Shower Basin 1.7mts long in the UK Electrical Forum area at ElectriciansForums.net
Can you fit a spur 1.7mts from a shower with a 1.7mts shower basin shower is at the other end of shower room.
The regs of distance in “A room containing Bath or Shower” have been slightly reduced within the 18th 3rd Ed, for RCD outlet.!
BUT it’s not clear from your question.!!
Are there 2x shower areas????
Have you RCD/RCBO protection????
Have you electrical/mechanical Extraction installed.????
So the shower is at one end of a shower room .The shower basin is 1.7mts long.At the furthest point of the basin from the shower 1.7mts can I fit a spur/flex outlet for a towel rail.
Reply to Shower Basin 1.7mts long in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a customer who is looking to replace their electric shower. There is equipotential bonding connected to the cold feed. I’ve not seen...
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
