I keep reading this but it doesn't make sense to me.
A spur is just an additional length of cable than connects to a ring final circuit.
What are you hoping to put on the end of the cable? An FCU, A socket??????
Can you fit a spur 1.7mts from a shower with a 1.7mts shower basin shower is at the other end of shower room.
The regs of distance in “A room containing Bath or Shower” have been slightly reduced within the 18th 3rd Ed, for RCD outlet.!
BUT it’s not clear from your question.!!
Are there 2x shower areas????
Have you RCD/RCBO protection????
Have you electrical/mechanical Extraction installed.????
So the shower is at one end of a shower room .The shower basin is 1.7mts long.At the furthest point of the basin from the shower 1.7mts can I fit a spur/flex outlet for a towel rail.
will the FCU/outlet be more than 600mm from the edge of the shower basin?
Reactions: DPG and timhoward
milton keynes
Shower Basin 1.7mts long
UK
R1D2,
R1D2,
