Can you fit a spur 1.7mts from a shower with a 1.7mts shower basin shower is at the other end of shower room.
The regs of distance in “A room containing Bath or Shower” have been slightly reduced within the 18th 3rd Ed, for RCD outlet.!Can you fit a spur 1.7mts from a shower with a 1.7mts shower basin shower is at the other end of shower room.
So the shower is at one end of a shower room .The shower basin is 1.7mts long.At the furthest point of the basin from the shower 1.7mts can I fit a spur/flex outlet for a towel rail.Can you fit a spur 1.7mts from a shower with a 1.7mts shower basin shower is at the other end of shower room.
Thanks answer foundwill the FCU/outlet be more than 600mm from the edge of the shower basin?
