Discuss Signs on power adapter. in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I am total noob in electric things. I've got one question. What is that sign on Dell PC power adapter? What is it and how to test it? Is it class two with earth? Help! Thank you.
Read the CoP for ISITEE
not sure that particular thing is in the COP. and how could it be tested anyway if it's a plug-in device and the output is ELV. visual inspection only IMO.
FVI, and if you like, test output voltage just for fun...
You could try testing it when plugged into the PC...
Oh, I dunno...
Pretty unlikely to be fatal...more likely to fail and be a costly replacement from Dell
Here's one I made earlier...
I expect if i peeled the Made In China sticky label off it would reveal more meaningless (to me) symbols...
The lead is a plain cloverleaf type, so easy to test...
Anyway, if you have an older Dell laptop and need this power supply, let me know. Yours for a charity donation.Dell ps.jpgDell ps.jpg
Indeed, DPG...lazy of me, but what I meant was it is easy to test that kind of lead on a PA Tester, provided you have the adaptor
Remember that a PAT tester connects line and neutral together during testing. And obviously there is no earth connection. So Pat testing a figure 8 lead doesn't actually do anything.
Edit: ignore me. I forgot it was a cloverleaf rather than a figure 8 type. Doh. I am currently stood in the corner.
Reply to Signs on power adapter. in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Insulation test live to earth = 0.7 ohms. This is a long length of buried swa cable (approx 100m) from mains in to submain. Test done with live...
I am a new PAT tester for a school, and I am stuck testing a plasma globe. It has a two core wire going to it, but no class 2 mark on the...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Hello everyone, I saw in the hospital every circuit has 2 separate cpc, same size, sometimes different. I'm wondering. How we can do the dead...
