L
Luke A
Hi guys,
I'm trying to set up a small circuit but having trouble getting my head around whats needed. I want some sort of push switch that when activated will open up the circuit for 2-5 seconds so a water pump will start and then stop. The problem is the button/switch will only be activated momentarily and cannot be held down.
Simply put I want a ball (a ping pong ball) to travel down a pipe, hit a switch which would start the water pump for a few seconds, then stop and be ready to do it all again without resetting anything. This is the idea I had in my head at first but as you can see I thought a simple on/off switch would be ok, but now I'm hoping it can be automated instead.
If anyone could tell me the simplest way to achieve this and where to look for parts I would very much appreciate it. Thankyou.
A pulse triggered relay timer is probably what you need although they can be a tad expensive, if a pulse is sent to the relay( ping pong hits pushbutton) then it will close an internal relay which can be used to run you pump for a duration you set it for.
Rs components do a range of timer relays there should be something to your liking there.
