Discuss single or double pole sockets in the UK Electrical Forum area at ElectriciansForums.net
OK, you may save 50p per point - so is it worth it or are you fitting 50+ - which would only be £25.00
And if you have problems later with RCD's you'll have to unplug everything too.
The Regs should be pushing for DP switches IMHO.
Reply to single or double pole sockets in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
