S
Sparkattack
Recently looked at a job to relocate a pump due to the poor location it was in for maintenance purposes. The current set up is a 230Va.c centrifugal pump rated 0.77KW 3.4A FLC fed from c type 6amp MCB to 16amp switched socket.
Am I right in saying that this needs to be changed to incorperate a DOL starter with overload protection as the motor is greater than 0.37KW? Or is the current set up ok?(reg 552.1.2) The motor will be constantly running as it feeds water to monitoring equipment and will have infrequent stop/starting.
