What does a homer mean? I don't understand
Homer.
put live on toungue if you get a slight tingle then good to go, ask for another pint as as hes taken the P.
True, as I have finished up for Christmas with my company I didn't have test equipment available. Will need to get it properly tested then. Cheers
Wow!!!! Might be too late after Xmas leaving a loose connection mate can cause them hot thingys called FIRE!!!!!
Hi there, new to site and looking for some advice. Recently rewired a small flat and extended some original ring mains, wiring was all pretty decent. Everything is good power wise, but my socket and see is giving me a reading of a phase fault. Took socket facings off and no loose connections and 230v in all. Appliances work as well within the ring main. Checked board and all connections are fine. Looking for any advice possible on what the problem could be without ripping whole ring main out.
Cheers.
Did you use your socket and see to determine this?
:rofl: this has to be the best one yet, OMG!!!!!!!!!!!!! I would only repeat what sintra said in the first reply, again OMG!!!!!!!!!!!!
A socket and see along with a neon screwdriver is the fashion now and replaces those old clumsy looking megger kits
i posted what Homer meant and have had four completely different examples, I think tels one is best
Ah yes very true Bud, and don't forget our trusted reliable friend the Voltstick, I wouldn't go to work without one :devilish:
I know what I would like to say to the OP. But find it difficult without resorting to swearing.
His fist post, it doesn’t work, I’ve no test gear, please help! It’s becoming a recurring nightmare!
Wonder what his day job is, if he comes back with industrial maintenance electrician I’ll scream!
i hate the socket & see brand of test gear , they remind me of fisher-price kids toys but less accurate :-D
as for the problems with ring mains , everyone knows the answer is radials. lol.
British Gas "Electricians" ( term used very loosely ) use Socket & See to determine if a circuit is suitable for adding a new boiler to.... Honestly
Had issue 2 years ago when one if their jokers got a zs reading of >100 ohm and told the customer her wiring was shot and promptly placed danger stickers on her ccu, if he had of had the right gear & training he might of noticed the TNS earth connection was shot to bits and Ze was actually over 100 odd ohms
