Discuss small plung circular saw in the UK Electrical Forum area at ElectriciansForums.net
I use a Fein and have a Festool plunge saw for big jobs. Will try the stanley knife as it is much simpler.
Used the Fein very carefully to cross cut a board and cut through the insulation and sheath of the T&E the previous "electrician" had laid on top of the joist. He had also used the CPC as neutral as he had cut the neutral too short at the metal wall light.
Bosch multitool is perfect for floorboards. You can cut perfectly, half way across the joist, just to the side of existing nails, then slice through the tongues. Don't think I would use anything else now. Never has making a hatch been so easy.
Btw, will get a Fein when I have saved enough :)
I favour the stanley knife method. I had to lift some polished wood floor boards that were on show in a grade 1 listed manor house, real brown trouser time. Used a stanley knife as there was only a 2-3mm gap to cut the tongue, then gently lifted the board. When the boards all went back down, you wouldn't have know I'd been there. Happy days.
Ok all i am going to hold back on the plunge circular saw and try the stanley knife method as it seems alot safer when trying not to hit cables or pipes and just use my hand floor board saw when cutting across a joist
If you want a neat job where you have to cut the board across the joist, then you won't go wrong with the Bosch PMF180 E Allrounder Multi Tool. Got mine from Homebase, on offer, on a 15% day for well under £60, and not looked back :)
I use either the Bosch PMF 180 or a mains voltage Worx mini circular saw from B&Q getting spare blades for the Worx is a pain tho.
Reply to small plung circular saw in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Just thoughts Id share my recent fun and games on my parents farm.. The electrics are old. Its a 400yr old house with outbuildings just as old...
Went to a job today simple job on the face of it , went to take up some floor boards and who ever had them up previously used a combination of no...
4K
