Discuss Smaller MCCB feeding larger MCCB-RCCB in the UK Electrical Forum area at ElectriciansForums.net
Have they used the 125a to protect the cable and then 250a for the RCD protection? I sometimes come across a 10a 60898 then a 32a 61009 separately before the first light for example.
Am I seeing aluminium cores involved?
I'm presuming, yes. The OP says "150mm 4 core ALI" in the first post. That is why I asked about installation method.
Reply to Smaller MCCB feeding larger MCCB-RCCB in the UK Electrical Forum area at ElectriciansForums.net
Hello All. New here and will be flooding with terrible questions for my own knowledge. Just trying to learn so some questions like this maybe very...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
