Dave301
Ive been having a read in the electricians guide to the building regs with regards fire safety and a Grad D LD3 system, with regards the wiring of smoke and heat alarms it says on page 147 that alarms are required to:
b) be permanently wired with an independent circuit to the dis board or preferably supplied form a local regularly used lighting circuit.
Would any one be able to tell me why it would be preferable to be supplied from a local lighting circuit rather than having its own independent circuit? And in this case how would you go about isolation for it?
Thanks in advance
Thanks in advance
